ERP
Valoracion de Cesser
<blockquote data-quote="sander" data-source="post: 11009" data-attributes="member: 14588"><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,</span></p><p>Sistel está muy bien, yo he trabajado con ellos y hacen un trabajo bastante fino. Lo más complicado es conectar la filosofía de tu empresa con la filosofía del consultor y hacerle entender que hay cosas que es mejor no tocarlas por experiencia propia. Si hay buena química entre la empresa y el consultor, y este sabe hacer correctamente su trabajo entonces hay muchas posibilidades de que todo salga bien.</p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p>Tengo un amigo que ha trabajado con Cesser y también esta contento con los resultados. Lo dicho, todo depende del consultor que te toque.</p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser</span></p><p>Supongo que es como dice el dicho....</p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser</span></p><p>Cada uno habla de la feria tal y como le ha ido y a veces las opiniones hacen que uno tenga muchas más dudas de las que se tenían antes de contactar con este tipo de foros, pero a su vez están bien porque desde luego si hay que realizar una pregunta de este tipo...este es el sitio adecuado.<span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser</span></p><p>Epero que tengas mucha suerte en tu elección.</p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser</span></p><p><span style="color: #e1ebf2">cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser</span></p></blockquote><p></p>
[QUOTE="sander, post: 11009, member: 14588"] [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser, cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser, cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,[/color] Sistel está muy bien, yo he trabajado con ellos y hacen un trabajo bastante fino. Lo más complicado es conectar la filosofía de tu empresa con la filosofía del consultor y hacerle entender que hay cosas que es mejor no tocarlas por experiencia propia. Si hay buena química entre la empresa y el consultor, y este sabe hacer correctamente su trabajo entonces hay muchas posibilidades de que todo salga bien. [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser[/color] Tengo un amigo que ha trabajado con Cesser y también esta contento con los resultados. Lo dicho, todo depende del consultor que te toque. [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser[/color] Supongo que es como dice el dicho.... [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser, cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser[/color] Cada uno habla de la feria tal y como le ha ido y a veces las opiniones hacen que uno tenga muchas más dudas de las que se tenían antes de contactar con este tipo de foros, pero a su vez están bien porque desde luego si hay que realizar una pregunta de este tipo...este es el sitio adecuado.[color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cesser,cessercesser,cessercessercesser,cesser[/color] [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser[/color] Epero que tengas mucha suerte en tu elección. [color=#e1ebf2]cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cesser cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cesser,cessercesser,cessercessercesser,cessercessercesser,cesser[/color] [/QUOTE]
¿Que es lo contrario de grande?
ERP
