Building highly parallel rugged computers for electronic warfare
CamilaP
Mensajepor CamilaP » Vie 03 Mar, 2017 3:44 pm
Electronic warfare systems are among the most challenging embedded systems to design and deploy. Not only do they require voracious amounts of signal processing, they also require more mundane server-style processing (for signal library maintenance, data logging, etc.) and are often packaged in extremely size, weight, and power (SWaP)-constrained environments such as under wing pods. As a result, advanced EW systems can benefit from consolidating workloads on a single machine with the means to efficiently execute these two very different processing problems using parallel virtual machine (VM) execution. Modern commercial off-the-shelf (COTS) 3U VPX boards based on Intel server-class processors are a compelling option for these sorts of systems.
Volver a “Ciberseguridad”
